ir 2870 jamming problem
  • eng_migo
    • Jun 2008
    • 16
    [Jamming] ir 2870 jamming problem
    i have a machine 2870 and it is jam paper between registration roller and the drum the paper look to be darpped from the middle
    note: only the first paper jammed ..... and if the machine stop for a while and try to copy again it is also jammed the first paper
    anyone have a solution for this problem
    Re: ir 2870 jamming problem
    There's been quite a lot of updates to this machine
    Is the registration sensor worn or does it have a metal edge?
    Does the lower right door have a foam pad stuck to the top.
    If the following parts are fitted the majority of jams in the right door are eliminated.
    FM3-1297-000 RIGHT LOWER INNER DOOR ASSY
    FM3-1296-000 RIGHT LOWER DOOR ASSEMBLY
    FL2-4520-000 FLAG, PRE-REG SENSOR
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      Skynet is wright but Are you a tech?Jam code dude!!
      • ikon01
        • Apr 2011
        • 53
        The registration flag rests against a sponge pad to prevent noise,they do go sticky.This may be worth checking too.Guys are right aswell(a jam code helps)
        • zoraldinho
          • Mar 2008
          • 5017
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            The picture you show does not represent the sponge noise dampening pad that was referred to above. The steel plate that forms the registration area has the reg sensor flag mounted to the back of it. Remove the steel plate to get at the back of it where the flag actuates the sensor. That flag rests on the sponge pad, and they get gooey, and present with "morning sickness" symptoms. After the machine has set still for awhile, the sensor flag is firmly stuck to the pad and will jam the sheet in the registration area.
            I just had to do this to an iRC3080 a couple of weeks ago, found it on my second visit, not the first...
            • zoraldinho
              • Mar 2008
              • 5017
              • eng_migo
                • Jun 2008
                • 16
                thx very very thx for ur help it works with me
                • mrfixit51
                  • Oct 2008
                  • 1975
                  You are welcome my friend,, I'm here to help when I can...
