ir 1022
  • shazza
    • Nov 2009
    • 96
    ir 1022
    Hi
    I have a problem on an ir1022 the original fault was that one of the flag sensors on the open/close cover was broken I tried repairing but plastic housing was beyond repair.
    It would feed sheets through handler and when job finished message that there was a jam in feeder came up all of the time ! on single and multiple copies.
    So I replaced the open close cover assy and now I get check Document all of time and single sheet jams at exit all of the time and no sheets can be fed through!
    When I put back the original open close assy I get the original fault back!
    Any Help would be appreciated.
    Shazza
  • teckat
    • 16083
    Re: ir 1022
    Originally posted by shazza
    Hi
    Shazza
    did u check the ADF spring loaded reg sensor for correct position /normal position is unblocked
    did u check the sensor to see if it is damaged ???
    what is jam code ??
    • shazza
      • Nov 2009
      • 96
      Re: ir 1022
      Hi,
      Do you mean sensor underneath adf on left hand side by removing 3 taper screws. Senor arm looks to be in place fine.
      Jam codes in history are 0007,0008 and now 000A with new open /close cover assy.
      I ran out of time to fault find but thinking to change all the senors X 3 but why different problems with open/close assy?
      shazza
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Re: ir 1022
        Sometimes tech must open something couple times to see issue.
        • shazza
          • Nov 2009
          • 96
          Re: ir 1022
          Hi Sorry what do you mean?
          • teckat
            • 16083
            Re: ir 1022
            pull off the covers to have better observation on issue
            • shazza
              • Nov 2009
              • 96
              Re: ir 1022
              Hi All,
              All sorted now replaced all 4 sensors and adf solenoid to cure!!
              Thanjks
              • teckat
                • 16083
                Re: ir 1022
                Hi All,
                Thanjks
                • zoraldinho
                  • Mar 2008
                  • 5007
                  Re: ir 1022
