I have a IR 3570 and I have been trying to stop the incoming faxes for this machine. Can anyone help me on how to stop incoming faxes but allow outgoing faxes other than unplugging the phone line......Thanks
IR 3570 need help with how to stop incoming fax
Re: IR 3570 need help with how to stop incoming fax
Perhaps you could increase the number of rings before pickup. After 32 seconds the sender will give up.
Or you could turn on distinctive ring. It would never answer. I like that one better.
You'd probably want to turn off the ringer volume also. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
-Enter Service Mode on the device then select Fax to enter the Fax Service Mode.
For stand-alone fax units
-Enter the Fax Service Mode.
Service Modes for various models
-Data Registration / #
-Menu / #
-Additional Functions / 2 / 8 / Additional Functions
-Additional Functions / 28 / Additional Functions / Fax
1.Select NCU (or #4B NCU).
2.Select 8. Auto RX.
3.Highlight or choose 007.The default setting will be 02 (two rings).
4.Change the value to a number much higher than 5.
expanded RX functions
The Auto/Manual RX setting is not listed under Additional Functions > Communication Setting > Fax Settings > RX Settings. These buttons are found under System Monitor > Fax > Received Job Status.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
How to Block Junk Fax Telemarketers
Definitions unsolicited advertisementMethods to stop the faxes- Put "Privacy Director" service from the phone company on your fax lines. Calls from unidentified numbers will be blocked.
- Calling them and asking to be removed generally does not work, as these scammers are already operating outside the law, they don't care, and will probably put your number of a list of now-verified fax numbers to sell to others scammers.
