have a nice day to all friends.. yester day i instaled a new ir2520. in dadf one copy is ok. more than one the original got jamming . same dadf worked good in other working machine. i checked all conectors . any one help me to solve this?
ir2520 dadf problem
Re: ir2520 dadf problem
post the jam codes !!!!!!
For the AA1 DADF use interface cable FM4-3025-000
For the AB1 DADF use interface cable FM4-3320-000
or
SR7 sensor is the Last Document Detection Sensor. In normal operation the sensor tells the machine when the last document has left the document tray.
check the actuator position
SR7.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**
