Canon ImagePress 6000VP Error Code 733 subcode 0000.
  • kisavw
    • Jun 2025
    [Error Code] Canon ImagePress 6000VP Error Code 733 subcode 0000.
    Good morning.
    Know someone back Code E733-0000-00 on the installation.
    This uppstog when I install a new machine and starts the machine and will initiate Pod and Stacker first time.
    The machine will find the first non-Stacker and Pod. Then got up just Stacker on Pod was off, when I then try to find the pod it gives E code. I restart will return the error. I start with no current to the Pod is the machine up with Stacker.
    To ensure Pod function, I tried to start the pod with 8 bit down on SW102 at Pod controller card to enter the adjustment mode. When the elevators and initiates Podcasts itself without contact with the machine.
    Very grateful for help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon ImagePress 6000VP Error Code 733 subcode 0000.
    Enter service mode and make settings for the connection order.
    COPIER > OPTION > ACCPST-P
    "Pod Deck 00100001" is displayed. => Input "1" and press "OK".
    1. Be sure to turn off/on the power switch after setting the connection
    sequence. If not, the accessory is not recognized.
    2. At power on after setting the connection order, be sure not to set a paper
    in the deck.
    Only in the case that there is no paper in the deck at power on, implement
    automatic 'Floatation Fan Air Flow Adjustment'.
    Be sure to turn on the main power switch of the host machine after turning
    on the power switch of the accessory.
    When turning OFF the main power, both
    the main unit and accessories must be
    turned OFF. When turning the main
    power back ON, turn the accessories ON
    first, then the main unit.
    In the case that the above display does not appear in service mode when
    setting the connection sequence, check the following points.
    1. The breaker [1] of the POD deck is turned on.
    2. In the settings of NODE_ID switch [2], "1" is ON and "2 to 4" are OFF.
    2. Check cable connection between DC controller PCB 1-3 and
    main controller PCB (MAIN-P).
    • kisavw
      Thanks for the reply.
      "Pod Deck 00100001" is displayed. => Input "1" and press "OK". This is done.
      in the deck.
      Up to this everything is correct by the Installation chapter.
      Have to chech the cables.
