Problem in high temperature ir 5000
  • bluesky2000
    • 95
    I have a problem in a heater in this part
    Where the temperature rises to a high degree
    Is it possible to minimize the temperature to a level not affect the operation of the device
    What is the way to change the temperature?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Problem in high temperature ir 5000
    Are you a tech?
    • bluesky2000
      • 95
      I have some information in this area
      • CT Copier Repair
        • Mar 2010
        • 304
        replace the thermistors
        Copier 101
        • zoraldinho
          • Mar 2008
          • 5007
          Don't. Call canon tech.
            • 16083
            [ATTACH=CONFIG]11997[/ATTACH]
            if u had a temperature issue / u would receive an ERROR CODE
            or a "Suspended" message on control panel
            Magneto.jpg call for a trained CANON Tech
            Temperature Control
            The machine uses the following methods to control the fixing temperature:
            Description> State
            NormalDescription> State
            Setting in service mode
            • bluesky2000
              • 95
              Copier 101
              can u show me wheres is ?
              Because I do not know the labels section in the device because they different from country to country
              Can you put a picture for this section
              Thanks for the help
              • bluesky2000
                • 95
                there is no error code or any thing in screen
                look my problem is :
                When printing large quantities of paper
                When the paper out adjacent to each other and the paper will be very hot
                This is the problem I thought that there is a way to reduce the temperature
                • zoraldinho
                  • Mar 2008
                  • 5007
                  that's the way it is
                  • Desert Rat
                    • May 2008
                    • 1089
                    If you are not a decent tech, this machine will eat your lunch. You may be having a problem with
                    the cooling fan that is in the front. Clean all the filters and make sure the fan in front is working.
                    Otherwise the heat will build up inside the machine and harden the toner in the cleaning unit.
                    Then the gears on the front of the drum unit will strip. Then it will drop used toner on the transport and leave gray
                    spots on both sides of the copy.
                    Good luck
                    DR
                      • 16083
                      and my problem is that u are not a tech/
                      I posted some SERVICE MODE adjustments
                      [9] Wait time reduction mode- to reduce print time; for iR5000, 4 min or less; for iR6000, 1 min or less.
                      [10] Priority on fixing mode-
                      [11] Priority on productivity mode-
                      [12] Thick paper mode (120/230-V model only)-
                      [13] Special paper mode -
                      COPIER>OPTION>BODY>FIX-TEMP
                      Use it to select down sequence mode.
                      0: OFF, 12: priority on productivity while controlling down
                      sequence temperature to
                      CHECK
                      Heat discharge fan (FM3)
                      Exhaust (lower rear)
                      • bluesky2000
                        • 95
                        thanks all very much
                        I will work with your advice
                        and i Will tell you about the result
                        thanks
                        • bluesky2000
                          • 95
                          thanks so much it working very good
                          • Desert Rat
                            • May 2008
                            • 1089
                            Bluesky2000,
                            It is customary to post what you did to solve the problem. That way there is a record of the problem
                            and the solution to the problem. This way everyone will benifit from the efforts put into your problem.
                            Someone else may have a similar problem someday and the solution will be available. Teamwork will
                            benifit everyone.
                            So please post what you did to solve the problem.
                            DR
                              • 16083
                              please post your findings- and the solution
