ir8500 cant boot
  • johnner66
    • Mar 2009
    • 265
    [Dead] ir8500 cant boot
    copier cant boot any ideal
    • 16083
    Re: ir8500 cant boot
    Progress Bar position ???
    any messages or error codes ?
    LCD is on or blank ?
    power to printer for warm-up ?
    did u try to remove & re-seat your Boot Dimm, Memory Dimm and HD ribbon cable
    if u can>>>>>>
    Check to see if the fixing temperature is increasing in service mode; COPIER>DISPLAY>ANALOG>FIX-C and FIX-E
    Assure there is no damage, or paper caught in the connectors.
    • chrisb
      Hey Johnner66, We need more info than that posted in order to begin helping. First, as Techat stated, does the progress bar freeze? are you getting a blank screen with just the green power light on the control panel? If the progress bar just freezes, have you performed a hdd scan (holding down the 1 and 9 keys while powering on the device) and allowing the machine to perform a hdd scan check? All of Techat's suggestions were very good and would be good troubleshooting starts, but we would really need to have a more descriptive account of your symptoms in order to provide any more help. Post back with more and we can help you.
