Can you Help me about 4570 with SST 4.52 ?
  • SYAFIQ
    • Aug 2011
    • 5
    Hello every body! I have a canon ir 4570 and SST 4.52, (ping -t is ok use cross cable) but I can't connect/detect with SST v.4.52 .
    Can you help me about this problem?
    Thanks, I am sorry about my english.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Can you Help me about 4570 with SST 4.52 ?
    -Normal Mode (download mode B)
    turn on the main power while holding down 1+7; then, make the following selections in service mode:
    COPIER>FUNCTION>SYSTEM>DOWNLOAD
    -Safe Mode(download mode A)
    turn on the main power while holding down 2+8
    Installing the System Software
    The system software that has been downloaded by the SST (version 3.01 or later) is saved in the temporary storage
    area of the HDD. You must then turn off and then on the main power switch so that the system software will be
    written to the system area, boot ROM, and flash ROM when the machine starts up. When you turn off and then on
    the main power switch for a second time, the machine will start up using the new version of the system software.
    [Registering the System Software]
    1) Start up the PC.
    2) Set the system CD in the PC.
    3) Start up the SST.
    4) Click [Register System Software]
    5) Select the drive in which you have set the System CD, and click [SEARCH].
    6) The list of system software found on the System CD appears. Remove the check from the folders and software
    you will not need; then, click [REGISTER].
    7) When the result of registration is indicated, click [OK].
    Making Connections
    [Procedure]
    1) Start up the PC.
    2) Check the network settings of the PC.
    - At the command prompt, type 'IPCONFIG', and press the Return key.
    - Check to see that the network settings are as follows:
    IP address: 172.16.1.160
    subnet mask: 255.255.255.0
    default gateway: any
    3) Check to see that the Execute/Memory lamp on the control panel is off, and turn off the main power switch
    (iR4570/3570, 2870/2270 Series).
    3-1) Hold down the power switch on the control panel for 3 sec or more.
    3-2) Follow the instructions indicated on the control panel so that the main power switch may be turned off.
    3-3) Turn off the main power switch.
    4) Connect the PC to the machine using a cross cable (iR4570/3570, 2870/2270 Series).
    5) Start up the machine to suit the download mode you will be using (iR4570/3570, 2870/2270 Series).
    - Normal Mode
    Turn on the main power switch while holding down 1+7.
    When the machine has started up, make the following selections: COPIER > FUNCTION > SYSTEM >
    DOWNLOAD.
    - Safe Mode
    Turn on the main power switch while holding down 2+8.
    6) Start up the Service Support Tool.
    7) Select the model of the machine to connect (iR2270/3570).
    8) Click [START].
    • SYAFIQ
      • Aug 2011
      • 5
      [ATTACH=CONFIG]12080[/ATTACH]
      1) Start up the PC.
      Making Connections
      [Procedure]
      1) Start up the PC.
      - Normal Mode
      DOWNLOAD.
      - Safe Mode
      8) Click [START].
      [ATTACH=CONFIG]12081[/ATTACH]
      [ATTACH=CONFIG]12082[/ATTACH]
      [ATTACH=CONFIG]12083[/ATTACH]
      Thanks a lot for your advice.
      I will try....
      • zoraldinho
        • Mar 2008
        • 5007
        I will try....
        • SYAFIQ
          • Aug 2011
          • 5
          1) Start up the PC.
          Making Connections
          [Procedure]
          1) Start up the PC.
          - Normal Mode
          DOWNLOAD.
          - Safe Mode
          8) Click [START].
          Step 1 - 6 is ok.
          But Step 7 and 8, no choice so I can't select a model and start.
          Thanks a alot.
          • totoro
            • 568
            Do you have the IR 4570 system software registered?
            Totoro
            • JustManuals
              • Jan 2006
              • 9838
              Yes, why?
              • teckat
                • 16083
                Step 1 - 6 is ok.
                Thanks a alot.
                sst.JPG this is where the firmware should be located below
                C:\Canon File Folder\SST System Software Folder\SST Files\iR2270_v40.03
                your firmware needs to be registered as shown under connect/if not select REGISTER FIRMWARE>SEARCH>Highlight iR2270>
                SST SEARCH.JPGthen elect REGISTER to add
                • zoraldinho
                  • Mar 2008
                  • 5007
                  Originally posted by manuals4you
                  Yes, why?
                  If you wont sell something,OK,but when we have technican Discussion you never help nobody,so you and your sarcasm i don't won't see again in my thread!!
                  • SYAFIQ
                    • Aug 2011
                    • 5
                    No, I will backup my HD/firmware.
                    Yes, why?
                    Originally posted by teckat
                    [ATTACH=CONFIG]12094[/ATTACH] this is where the firmware should be located below
                    [ATTACH=CONFIG]12095[/ATTACH]then elect REGISTER to add
                    Thanks a lot for your share.
                    I will try..
                    I agree.......
