Ir2010f
  • copicatt
    • Nov 2008
    • 366
    [Jamming] Ir2010f
    Customer called with jam they couldnt find. Upon arrival.....I couldnt either. False jam, points to area 1,2, and 3, which is everywhere. Went to service mode to do a sensor test per the manual. For some reason, it does not list these sensors and cant print out a jam report of course, which is pretty silly in itself because it wont work. Duh! There are only 3 jam sensors: cassette retry, registration, and delivery. All are free from obstruction and the flags are wirking corectly. I blew them out, but no luck. How do I pinpoint the sensor? I reseated all connections on dc controller also. This happened after removing an adf jam, which is strange. Adf is still working because they can send faxes still, but cant print out what is received. Anyone had this problem. I am using an ir2000 manual.????
    • 16083
    Re: Ir2010f
    Jam Indication "REC PAPER JAM [1.2.3]" Being Recorded ????
    Check if the fixing unit door shaft retainer (item two, part number FB6-1493-000) is broken.
    Replacing the part should resolve the jam indication.
    Item is shown below.
    • COPIERTEC ASSOCIATES
      • Aug 2011
      • 279
      Re: Ir2010f
      Did you try to check the fixing unit? Many times the paper gets stack in this unit and gets hidden,also ensure that all the sensor flags are at home position.
      • copicatt
        • Nov 2008
        • 366
        Yes I did look down in the fuser but didnt see anything. Anyway, it us showing constant jam at power up and there is no paper sensor in the fuser to be blocked. All sensors are at home position. I will look at the image on the previous post......
        • copicatt
          • Nov 2008
          • 366
          Teckat, I cant view the image on my phone but will check it later. Is is something noticeable looking at the machine? Thx
            • 16083
            Re: Ir2010f
            The machine is equipped with 3 jam sensors used to motor the movement of paper. In addition to these sensors, the machine is also provided with sensors to find out the presence/ absence of paper in the cassette and manual feed tray (1 pc. each).
            The presence/absence of paper or of a jam is checked at such times as programmed in advance in the CPU of the DC controller PCB and in relation to the presence/absence of paper over a specific sensor at a given time. If the machine detects a jam, it will turn off the main motor (M101), and will indicate a jam message in the control panel.
            The following are the sensors used to monitor the movement
            Delay jam--Stationary jam--Stationary jam
            at power-on
            PS101---Registration paper sensor---- Present------------------------------------- SAME FOR ALL
            PS102---Paper full sensor-------------Absent------------------------------------- "
            PS103---Delivery sensor--------------Present------------------------------------- "
            PS105---Multi-feeder paper sensor----Absent------------------------------------- "
            PS151---Cassette paper sensor-------Absent------------------------------------- "
            PS152---Retry sensor----------------Present------------------------------------- "
            • copicatt
              • Nov 2008
              • 366
              I saw that chart in the book, but didnt quite know how to use it. Theres no where to check each ones state. Unless I am missing something. The part you mentioned: I did norice it was bent somewhat. Does that cause a problem?
              • copicatt
                • Nov 2008
                • 366
                Teckat, your a lifesaver. It was cracked and bent up riding on that little tit. Repositioned it back into place for now. Fired right up! But why? Does it move the flag out if position? Thanks a million!
                  • 16083
                  Re: Ir2010f
                  Thanks,
                  it's a Canon Engineering thing I guess
