DADF H1 on iR2800 Jam
  • mrfuser
    • 1626
    Paper just seems to stop before it makes it through the feeder. Not hitting a thing, just stops. Anyone seen this?
    Kelly
  • ikon01
    • Apr 2011
    • 53
    Re: DADF H1 on iR2800 Jam
    what have you tried?have you replaced the feed rollers and sep?whats the jam code?
    the first pass sensor has a sponge pad noise dampener on the actuator to prevent noise,these can go sticky!
    the feed is driven by a slip clutch on the rear drive assy,the wrap springs can break (FG6-7677-000)
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Try to initialize sensors.
      • teckat
        • 16083
        Kelly
        JAM CODES or Error codes ????
