Gp30f Ip Core Board Diagram
  • bisu_khurda
    • Dec 2007
    • 16
    My GP30F IP CORE BOARD IS NOT WORKING PROPERLY. ITS MAKE A BLACK LINE AT THE TIME OF COPY. ANY ONE HELP ME & PROVIDE ME THE IP BOARD DIAGRAM FOR REPAIR THE BOARD
    • 23009
    What makes you think its an image processing board problem? Have you run any internal prints to verify that the problem is not optical? Have you considered other likely causes like worn drum, damaged transfer roller, etc.?
    Image processing board technology is typically way over the head of an average (and most above average) copier techs. The last time I vainly attempted to fix a controller board, I found a cold solder joint on 1 leg of a 100 leg chip. When I got out my soldering iron & glass I realized that the tip of the iron was as wide as four of these miniscule legs. There was no way I could repair this simple cold solder joint with such clumsy tools. If you truely have a bad image processor board you won't be able to fix it yourself.
    • bisu_khurda
      • Dec 2007
      • 16
      But the Other functions are running correctly, When I Test the IP Board by Copier, Its shows that the IP is OK. So I think there is a minor problem. The Technician tell me that he can remove the IC and solder the new one. But he wants the schematic Digrams of the IP Board. By which he will findout the fault & repair the board. I am already test the IP Board an another Caopier Machine. The result Was same Problem. So there is no problem in Optical or Drm or transfer roller.
        • 23009
        You should have said so. I still don't think that you can repair the IP board yourself. I don't have a schematic regardless.
        • bisu_khurda
          • Dec 2007
          • 16
          You have any Idea to get the Diagram ? I found a site which link I give u. Plz look it and suggest me that the Diagram is there or not.
          LINK : PrintCopy - download service manuals
            • 23009
            If its available, it will be in the section called 'cd-circuit diagrams English'. Some of these circuit diagram books have breakdowns to board level, some don't.
            $11.00 is a reasonable price for the manual set. Our resident manual seller charges $11.77 since January 2008.
            Good luck. You'll need it.
            • bisu_khurda
              • Dec 2007
              • 16
              I purchase the file today what happens next I will tell u
              • bisu_khurda
                • Dec 2007
                • 16
                • bisu_khurda
                  • Dec 2007
                  • 16
                  The IP Diagram Given in Mannual is nut sufficient. Its shows only Jack Information biut The IC & other equipments infomation are not available
                  • bisu_khurda
                    • Dec 2007
                    • 16
                    I want a GP 30F IP board
                    Hey, Ithe IP board was not repaired by me. Anybody tell me that how can I get a New IP board
                    • Irish
                      • 110
                      Now theres a surprise...
                      • lkrsardis
                        • Dec 2007
                        • 316
                        gp30
                        yes, buy a new machine !
                        Like the United States Postal Service It's a miracle it works!
                        • Hombre
                          Service Engineer
                          • Jan 2008
                          • 24
                          You can order it by Part Number to your local Canon distributor. Look in Parts Catalog at Figure 935. Pay attention to order that part number that matches your serial number of the machine, otherwise it will not work.
                          • bisu_khurda
                            • Dec 2007
                            • 16
                            How Can I purchase the IP Board Online. Because the Local Distributor Have No IP Board
