Print sequence
  • Alessandro72
    • Jul 2009
    • 31
    Print sequence
    Dear friends,
    in the Canon clc 1110 there is a method to change the sequence of the 4 color printing?
    For example, to print the first yellow then black magenta and cyan?
    Is an unusual request but I could use for testing.
    Thanks to all those who want to help me.
    Alessandro
    https://t.me/pump_upp
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Print sequence
    TEST>PG>TIPE
    • Alessandro72
      • Jul 2009
      • 31
      Re: Print sequence
      Thanks for your reply but I can not find the solution in menu that you have shown.
      Maybe I have not explained well.
      The printer uses to generate an image a certain sequence of 4 colors (C, M, Y,K), I would like to know if there is a possibility to change this sequence.
      • zoraldinho
        • Mar 2008
        • 5015
        Re: Print sequence
        You don't have service manual,do you?Are you a tech?
        • Alessandro72
          • Jul 2009
          • 31
          Re: Print sequence
          This is the menu, I do not see the possibility of exchanging the order.
          I am not a technician but I would like to become one!
          • zoraldinho
            • Mar 2008
            • 5015
            Re: Print sequence
            Why do you won't to change order?Where is the problem?
            • Alessandro72
              • Jul 2009
              • 31
              Re: Print sequence
              There are no problems, I just want to experience the gamut variations changing the sequence for printing!
              • vigour
                • Aug 2010
                • 1038
                Re: Print sequence
                That screen is for techs to do test prints, for troubleshooting.
                IMPOSSIBLE. It does not change the sequence.
                The devs are fixed on a rotary, and always spin in the same sequence.
                  • 23009
                  Re: Print sequence
                  All you would need is a Canon engineer to re design your machine, and re-write the firmware for just your machine. I'm sure if you waved enough money at Canon they might do it for you. Curiosity doesn't seem like a very good reason though.
                  It's not about just swapping a couple of components. The timing of the entire machine would be affected. Do you have a better reason than just curiosity? =^..^=
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Re: Print sequence
                    Kinda like changing the firing order of the cylinders of the engine in your car.
                    Not possible.
                    • teckat
                      • 16083
                      Re: Print sequence
                      Originally posted by Alessandro72
                      Dear friends,
                      Alessandro
                      CLC1100 SERIES
                      When making a 4-color copy, locking will be M, C, Y, and Bk in sequence.
                      That is it~~~~~~~~~~~~~~~~~~~~
                      • teckat
                        • 16083
                        Re: Print sequence
                        Not possible.
