imageclass mf 5550 scan issue
  • pontiac
    • 420
    Having an issue trying to get copier to scan from adf will only scan from platten when command is sent. We have reloaded drivers and still will not pull docs from adf. Adf works when coping and faxing. Any ideas? Thanks.
  • teckat
    • 16083
    Re: imageclass mf 5550 scan issue
    hope u are not using windows 7 or Vista=no support drivers
    MF5550
    There are two methods of scanning documents to your computer:
    Using a TWAIN- or WIA- (Windows XP) compliant Windows application
    Using [SCAN] on the operation panel of the machine
    IMPORTANT
    When using [SCAN], the ADF is not available for scanning.
    When using the WIA driver, the ADF is not available for scanning.
    For better scanning quality, we recommend that you place documents on the platen
    glass. If you use the ADF, the scanned image might not be clear.
    USE A TWAIN DRIVER
    • teckat
      • 16083
      SEE THIS GUIDE>>---MF5550 GUIDE.pdf
