IR5065 intermittent jam
  • cweber0531
    • 71
    Having an intermittent jam on an IR5065, jam code 0103 at PS26. Everything checks out, sensor roller etc. Happens randomly on large print jobs after 20-50 pages. Any ideas on what it could be?
  • ernesto
    • Oct 2011
    • 430
    Re: IR5065 intermittent jam
    Have you replaced pickup roller , feed roller and separation roller ?
    • teckat
      • 16083
      iR 5050 / 5055 / 5065 / 5075
      Motor Driver PCB
      FM2-9895-000
      0103 is the delay to vertical path 1 paper sensor PS24
      PS26 is vertical path 3 sensor-
      Vertical path lower motor drive signal/M27-stepping motor-could be crappy
      • Herrmann
        • Jan 2006
        • 792
        Go into service mode and check the jam history.
        What codes do you get ?
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • teckat
          • 16083
          poster>posted code
          • Herrmann
            • Jan 2006
            • 792
            ooops
            sry, i overread that
