how can i install imagepress server q1 with c1+
  • nightmuv
    [Misc] how can i install imagepress server q1 with c1+
    is it possible?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: how can i install imagepress server q1 with c1+
    C1= q1,t1
    C1+=q2,t1
    • alexctx
      • Dec 2010
      • 157
      if you can.
      q1 is installed. sistem sotfware of q2. and if printed,
      C1, C1 +
      • teckat
        • 16083
        Q1-v1.1=C1
        Q2-v2.0=C1 v53.03 or later
        " "-" "=C1+
        • charm5496
          • 2387
          Originally posted by nightmuv
          is it possible?
          You need to upgrade the Q1 to a Q2 with the software then it will work
          • zoraldinho
            • Mar 2008
            • 5015
            I never do this.Is this possible??
            • teckat
              • 16083
              How is that possible ???? never see info for that procedure
              Servers have completely different Hardware
              imagePRESS Server Q1/Q2 Comparison Chart
              Differences between imagePRESS Server Q1/Q2?
              see pdf>>Q1_Q2 SPECS _TP08-1.pdf
              • charm5496
                • 2387
                yes I have two Q1's in the field both on C1+ models running Q2 software
                have a read:aid=68419.pdf
                Keep in mind that it doesn't support the clear toner which we do not support anyway so not a big deal on our end.
                • teckat
                  • 16083
                  have a read:[ATTACH]12419[/ATTACH]
                  Thanks, completely forgot about that,
                  funny thing is ,i never had a request for it-
                  out IT midgets keep it to themselves
                  • charm5496
                    • 2387
                    we had a sales rep forget to include the Q2 on one sale so we had to improvise there and then we took over an account that had a C1+ with a T1 and they wanted better quality and job management so we took a Q1 and upgraded it there as well. Saved quite a bit of money because of this!!!
                    • alexctx
                      • Dec 2010
                      • 157
                      if you can print the clear toner.
                      is sent as the t1v2.0 (layers).
                      we have c1 + with q1. wint system sotfware of q2
