Banding / Mis-Registration on IRA 50xx
  • Paul 75
    • Oct 2008
    • 97
    [CQ] Banding / Mis-Registration on IRA 50xx
    Top to bottom banding (Not lead to trail ) on all colours. Very noticable on half tones and PG 6 test prints. Looks like width of drum or dev roller. After changing Drums , dev assy 's , Main Controller 2 (as per ATI from Tecktat !) ITB mod kit and 2nd transfer roller still apparent. This also gives noticeable mis-reg both horizontal and vertical which when manually adjusted to spec, still cannot be locked in via service mode. Last chance saloon was a firmware upgrade..... success.
    DC - v63.01
    Main - 61.05
    Timing fault on drum drive motor timing which with update was ammended.
    Oh...... I can't copy at the moment then ? !!!!!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Banding / Mis-Registration on IRA 50xx
    Please post pic.I'm very interesting.
    • charm5496
      • 2387
      We have had one 5051 with similar banding issues. Machine is in a print shop which is horrible and has 790K on it when the image issues really started. I have to say the main drive is not fun to replace and just about as bad as the IRC-3200 and 5180 series. Luckily there are fewer connectors to worry about and these newer connectors are a lot nicer!!!!
