I have ir 6570 im disconnected sorter but machine show me sorter is connected and when i use print a message show me " Remove the paper form the output tray" please help me what to do
sorter problem
Re: sorter problem
check in Service Mode/ if it indicates the Finisher is still connected
Under Common Settings>Tray Designation>
see if sorter is Shown>
if shown>
initialize common settings, select Additional Functions > Common Settings > Initialize Common Settings and select 'Yes'. To Initialize Copy Settings select Addition Functions > Copy Settings > Initialize Copy Settings and 'Yes'.
Note:
After performing these functions the imageRUNNER should be power cycled off and then on.
Then u can re-input any changes back in to Common settings/Copy settings u had before**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: sorter problem
this below reads "1" or "2" ???
COPIER > DISPLAY > ACC-STS
SORTER indicates the connection of the finisher and puncher unit.
sorter type 0: none;
1: finisher;
2: saddle finisher;
3: shift tray
punch type 0: none; 1: 2-hole; 2: 2/3-hole; 3: 4-hole (fr); 4: 4-hole (sw)
do u have a PUNCHER ATTACHED
try an MMI clear ?Last edited by teckat; 10-20-2011, 01:00 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Last edited by teckat; 10-20-2011, 02:34 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: sorter problem
Shift Tray-D1/ remove the upper left side cover on printer/ check for a shorted connectors
see pic below/ green circle/ click for better view
did u ever have a Shift Tray connected ????/ cannot have with FINISHER ATTACHED
TRAY.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
