canon ir3300 bypass fails
  • polo
    • Aug 2025
    [Jamming] canon ir3300 bypass fails
  • teckat
    • 16083
    Re: canon ir3300 bypass fails
    what are the Jam codes ?? if any
    check the flag of PS22 the multifeeder paper sensor
    make sure the black plastic cam follower #13 on the right side of the lower door has not fallen off-will prevent the flag of PS22 the multifeeder paper sensor from reaching the sensor when the door was closed.
    Pickup from the multifeeder tray fails
    /does the pickup roller rotate) ??
    Multi-feeder paper sensor (PS22)
    Place paper in the multifeeder.
    Does bit 5 change from ‘0 to ‘1’? (service move COPIER>I/O>DC-CON>IO-PO16)
    NO: Check the wiring and the link; if normal, replace the sensor.
    Multi-feeder clutch (CL2), DC controller PCB-
    Execute the following in service mode: code 2 of COPIER>FUNCTION>PATH-CHK>CL; i.e., CL-ON. Is the clutch drive signal present between J302B-7 and -8 of the DC controller PCB? (J302B- 7: 24 V, J302B-8: MLT_CL)
    YES: Check the wiring; if normal, replace the clutch.
    NO: Replace the DC controller PCB.
    Pickup from the multifeeder tray fails/ does the multifeeder holding plate fail to move up) ??
    Execute the following in service mode: code 4 of COPIER>FUNCTION>PART-CHK>SL; i.e., SL-ON. Is the solenoid drive signal present between J308A-1 and -2 on the DC controller PCB? (J308A- 2: 24 V, J308A-1: MLT_SL)
    YES: Check the wiring and the link; if normal, replace the solenoid.
