clc1110 E071
  • br21
    • Jan 2008
    • 22
    clc1110 E071
    hi!
    i have a problem with clc1110...
    after powering up i have an error E071 F000
    how to solve it? what it means?
    sometimes also errors E355 & E354 occur...
    thanx for help
  • djzolla
    • 71
    hi there
    well ive had years of experience on these machines and seen this error loads so ure in luck
    1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
    i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
    is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
    change the connectors mate would be my 1st conclusion for that error let me know how u go please...
    the other errors arent even coming up in the manual which points even more to the connectors.
    good luck
