canon ir 5000 no seperation
  • bonjing
    • Aug 2006
    • 18
    hello to everyone, i have a canon ir5000 but im having problem with the seperation of paper, i've noticed the corona wire is not lit, i've already change the ff: dc controller, hvt board, unit1, hvt transformer, can anyone pls. help me with this problem.
  • nasertop
    • Aug 2011
    • 40
    Re: canon ir 5000 no seperation
    change the housing of transfer separation corona assly & try what will happen
    • jper34
      • Sep 2011
      • 225
      id replace the transfer/sep corona unit,if that doesnt work, remove pre-transfer corona,sometimes that corona will cause this issue. if pre-transfer is shorting out, it will draw down the trans/sep. corona voltage.good luck..
      • bonjing
        • Aug 2006
        • 18
        thank you, problem solved i removed the pre tranfer corona, and it works. :-)
          • 16083
