Canon iR3035 producing faded line at top and bottom of page
  • Steve123
    • Jun 2025
    [Misc] Canon iR3035 producing faded line at top and bottom of page
    Experiencing some fading issues which over the past month have got much worse. It seems to be in a strip about 1.5 inches wide and about 1.5 inches from the top and bottom of the page. Worse when copying than printing. I have attached a copy of an open platen cover copy which shows what is occuring. Could you please let me know what you think could be the problem. Thanks!
    • 16083
    Re: Canon iR3035 producing faded line at top and bottom of page
    First-make sure Transfer Roller is seated properly./Check the front and rear transfer arms for proper positioning/When positioned properly, each end of the transfer roller should "spring back" after being pressed. If the roller is not positioned correctly, check that the springs on each end are in place.
    try---------------this
    Print out a P Print /w settings
    do a DC-CON clear in service mode/ Power off/on printer /re-input your DC-CON SETTINGS
    • Rachid.Akli
      • Oct 2011
      • 595
      Hello.
      My idea is just open any door during printing or copying cycle and have a look on the drum image density. Is the right door solidly closing?
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
