I have repaired a canon ir2230 copier ,it gives Error: E000000-0001 and i found the resistance Broken, I replaced it with a new resistance, but after copying 50 pages it gives the same Error and i found the new resistance broken again !!!! can any one help me !!!!!!!
Heater Brocken 3 once !!!
Re: Heater Brocken 3 once !!!
once years ago I Had E000 with a canon ir 3530 it was new, it only had about 700 copy, maybe was the general electrical net (it was not a problem of the copier), I Think this photocopiers are very special with it, and for it was broken the resistence. -
When the ceramic heater element has cracked into two or more pieces with apparent arcing from the heater element/ repeatably( more than once)
Cut all the wire ties on the wire harness running from the fuser assembly to the DC-CON PCB and Power Supply.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
