JAM cod 0210 IR7105
  • HELIO240
    • Jan 2011
    • 137
    [Jamming] JAM cod 0210 IR7105
  • teckat
    • 16083
    Re: JAM cod 0210 IR7105
    02xx stationary jam
    xx10 duplexing outlet sensor PS61
    This is only when duplexing from tray 2 ?
    what paper size is in tray 2 ? does it display correct size on panel ?
    what happens on two-sided from other trays ??
    did u check this below in service mode ???????????
    P002 XXXXXXXXXXXXXXXX
    BITS-15--------------------0
    COPIER>I/O DISPLAY<DC-CON>
    Address-P002-BIT #2 =duplexing reversal sensor PS12 = 1: paper present
    • HELIO240
      • Jan 2011
      • 137
      First thank you for your attention,
      Rushes so the jam when using the drawer 2 in one-sided copies or printers. When using two side of the drawer 2 is not defective. A4 and the same paper used and displayed. When using other copies or prints of drawers is not the problem. Still have not checked the bits of the mode i / o. Do you have any idea about the defect. As we have said already checked and changed some items from another machine with this next, as the process unit, duplex unit, ps61 sensor connectorof the duplex, duplex pull together, dc controller, machine upgrade and feeding 2.
      I am no more ideias.Sorry me for some mistakes in my English.
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        As you've mentioned it, the machine seems to work normally with the other drawers. So, the anomaly is with drawer 2. It could detect a wrong paper format (it is detecting a shorter format). That's why you've a stationnary jam. I mean, PS61 is detecting a longer paper size than the one put in drawer 2.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • HELIO240
          • Jan 2011
          • 137
          hello thanks for the tips personal problem solved, the problem was caused by broken wire in the harness connector of the feeding 2.After exchange the same problem was solved. Thank you.
          • teckat
            • 16083
            investigation.jpg_______procedure inspection= success
