iR4570 - Jam 0105 only from the first tray. Swapped all tires from Tray 2 and T2 still works fine whereas from T1 cannot run even a single sheet. Looked at a TB and it suggests replacing the following parts:
FB6-4852-000 - grey vertical path roller x1
FM3-1298-000 - GUIDE, DECK PATH x1
FM3-1296-000 - RIGHT LOWER DOOR ASSEMBLY x1
FM3-1297-000 - RIGHT LOWER INNER DOOR ASS'Y x1
FU6-2974-000 - SPRING, TENSION x1
FC5-0567-010 - PLATE, PICK-UP ASS'Y MOUNT, U x1
FC5-0641-010 - COVER, PCB x1
Are all these parts necessary to be replaced please, or is there more (lol) ?
Seriously, is there anything else beside replacing all those parts that can fix the problem, please?
Thanks in advance!
Thanks in advance!
