ir3300
  • universaltvm
    • May 2010
    • 52
    [Jamming] ir3300
    hi everyone i have a ir3300copier which has a reading of 1.5lakhs copies, now the copier is showng a eroor ie jamming in duplex area, i checked there and i didnt find any paper there, i cleaned the sensors/replaced, still the jamm problem is there, what is the issue
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: ir3300
    Here attached the jam errors and the position of the detectors.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • universaltvm
      • May 2010
      • 52
      Re: ir3300
      i tried with all these, the problem is still there
      • doktor
        • 215
        Re: ir3300
        Write the jam code.
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          Re: ir3300
          you have jamming paper in duplex area ....that means it have something sensor was broken there ..try change it ....or enter at service mode to reinitialized all memory ...we waiting the error message if you have in this ir3300 ?
          BEST TECHNICIAN . NICE PEOPLE .
          • universaltvm
            • May 2010
            • 52
            Re: ir3300
            it is not showing any error code it shows paperjammed plz emove it , it is on the duplex or in the fixing area
              Re: ir3300
              The jam code will be displayed in service mode, copier / display / jam.
              • DIMM
                • Nov 2008
                • 44
                Re: ir3300
                We had a publishing company as a customer. But it was impossible to set the series iR2200 to 3300 in their building.
                We believe it was something electrical breakdown when they started the presses at night. A DC-CON clear, followed by a sound from the duplex area, were performed almost every day.
                But all the other Canon printers have worked well there.
                • universaltvm
                  • May 2010
                  • 52
                  Re: ir3300
                  jam code
                  • COPIERTEC ASSOCIATES
                    • Aug 2011
                    • 279
                    Re: ir3300
                    Does the machine show paper jam immediately it is switched on? If so check on the sensor flags and the wiring.If the machine shows the jam during copying,check on the duplex drive belt and the general drive system of the duplex.
