canon ir3035 jamming in duplex.
  • srv
    • Aug 2008
    • 82
    Hi guys.I have an ir 3035 that is jamming in duplex.what happen is that after the first side is printed and the paper is coming up to the drum to print the second side the paper gets caught in the drum unit.when I use fresh paper it works fine.The paper being used is recycled paper made from ecf pulp(elemental chlorine free).If the paper is in the paper tray for only afew hours without being used it can jam and you can see any copies that do come out have a curl in them.Is this copier particulary sensitive to recycled paper?.Also does recycled paper tend to absorb moisture quicker or react poorly to moisture in a shorter space of time than better quality paper.Is the canon paper any good as I will advise customer to get some if it helps matters.The paper being used is 80 gram.cheers!!
  • teckat
    • 16083
    Re: canon ir3035 jamming in duplex.
    recycled paper=Shovel crap.jpgget the picture !!
    Process of elimination= Use regular 80 gram quality paper
    u can register Recycled Paper location in control panel in-
    User Mode>Common Settings
    also in service mode>>>>>>>>>
    COPIER > ADJUST > HV-TR
    TR-SPP Entering an output adjustment value for thick-paper transfer bias (for simplex printing on thick paper and duplex printing on the 1/2 side)
    - Increasing the value is very effective.
    Machine Environment/ How paper is cut from bolt(direction)/Interior Static charges/Print %Coverage/
    All effect paper----
    Plain and Recycled paper are from 17 to 24 lb bond (64 to 90 g/m2).
    Recycled*
    Load paper heavier than 20 lb bond (81 g/m2) in
    the stack bypass
    • srv
      • Aug 2008
      • 82
      Originally posted by teckat
      recycled paper=[ATTACH=CONFIG]12699[/ATTACH]get the picture !!
      Recycled*
      the stack bypass
      Thanks for response teckat.Advised customer to get decent quality and will take it from there.
      • jacky_kuo
        • Aug 2011
        • 54
        We tried all the canon to our service information ,
        and adjust the service mode the data is no use.
        You can try this improved package.
        This set of improved parts,
        We have used 4 to 5 years,
        Prevent jam code 0107 very useful.
        • jacky_kuo
          • Aug 2011
          • 54
          You can try the improved package.
          This set of improve parts,
          • jacky_kuo
            • Aug 2011
            • 54
            Originally posted by Canon.Tech
            Not seen these modified parts, looks like you just ft them to the drum, are they available from Canon??????
            Yes ,
            This is a self-developed in China.
            From IR3045's ~ iR3245's the photosensitive drum unit track,
            This has been set aside space for the modified parts.
            • Irish
              • 110
              Run duplex in A4r direction ....
              • Simons
                • Jun 2008
                • 490
                Yes the real fix is quality paper to fight the humidity in the air. Setting up the machine for a humid environment will help too.
                check display/ analog / humidity. What is the percent humdity 45% or more? will cause duplex jams.
                • mabawser
                  Tech
                  • Sep 2009
                  • 121
                  we have the same issue on these machines but the customer is using good paper. Its xerox a3 paper. the jams only seem to appear on a3 at the minute. cant seem to see why.....put fresh paper in the machine and it works for sometime only a couple of hours then starts jamming again (A3).
                  can you order those drum mod bits direct from canon? cant seem to find anything about them?!
                  havent checked the humidity but will check next time im on site but the office isnt anything out of the ordinary...maybe slightly on the warm side (as the woman said...its cozy!!!)
                  • DarkoMAL
                    • Jun 2013
                    • 13
                    [ATTACH=CONFIG]12830[/ATTACH]
                    Any link where we can order this parts ?
                    • copier tech
                      • 8169
                      Seen this many times on this series. The only reliable way is to run the machine on 100GSM, the thicker paper doesn't curl on the first side so doesn't catch & jam in the fuser or drum
                      • saifnauman
                        • Sep 2016
                        • 4
                        I m having same problem in my ir3045n paper curl everytime I copy and it jam when print both side I do cheap photocopy bcoz of other competitors so I can't use thick paper it cost a lot so please if anyone give me the advise how can I prevent paper being curl.. .
                        Thanks in advance
                          • saifnauman
                            • Sep 2016
                            • 4
                            Originally posted by skynet
                            Thanx a lot dear sir gr8 information Thanx once again I'll try that one
                            • mramlawi
                              • Jul 2011
                              • 838
                              im facing a jam 107 unable to solve , i replaced drum,right door, pickup untis,update the firmware to 22.0,used paper 80 grm and still facing the problem .
                              but the weird that the paper stuck under the grey roller loctaed in the right door its cruled inside it.
                              Distinguished road makes you jewel in rough
