canon ir3035 jamming in duplex.
  • Riviera
    • Sep 2016
    • 66
    Re: canon ir3035 jamming in duplex.
    with that model and all similar models you want to scrape off all noise suppression pads located in right hand door. You will find them under all paper guides operated by a solenoid. With age they get sticky and the guides will stick to them causing jamming problems.
    • Canuck
      Tech Specialist
      • 1713
      Remove all sticky dampers...under upper duplex guide also. If it does it when they use crap paper,tell them sorry...buy some decent paper.
        • 16083
        Like stated, but better paper.
        Or send out your duplexes to Staples/ Office Depot and give them the headaches.
        Low end Canon's have a poor record on duplexes.
        • saifnauman
          • Sep 2016
          • 4
          #19
          Originally posted by mramlawi
          im facing a jam 107 unable to solve , i replaced drum,right door, pickup untis,update the firmware to 22.0,used paper 80 grm and still facing the problem .
          but the weird that the paper stuck under the grey roller loctaed in the right door its cruled inside it.
          Is the paper jam when you command single print or multiple paper print
          If there is jam when multiple print then you should clean the solenoid or replace it
          It is in the fitting or simply replace the entire fitting buy a secondhand fitting it's not so much expensive
