Need Colour Copier
  • Mrigen
    • Oct 2011
    • 19
    [Misc] Need Colour Copier
    I am looking for a used canon colour copier.I saw d machine IR3220 so please suggest what should i do about d machine or please recommend which model is the best of that range.
  • iRC
    Summer trainee!
    • 96
    Re: Need Colour Copier
    iRC3220 ain't that bad option, but I'd choose a device from the iRC2380-3580 range. Those devices are real workhorses; we have few of them with over 600k in meter, and they are still running with original fusers etc. Much more worry-free device than iRC3220 or 3200.
    • Max
      • Oct 2011
      • 557
      Personaly if i had to spend my own money i would go for ricoh
      • charm5496
        • 2387
        both the 3220 series and 3480 series machines are good devices. From a repair point of view I like the 3220 series and the print quality is better than 3480 series. If you have the extra money a 5180 series is just as easy to work on as well, but the fuser assembly is a little costly, but a real work horse. We have several of these in the 2.5 - 3 million range.
        • teckat
          • 16083
          iR3220
          LOOK FOR A LOW VOLUME ONE
          • Mrigen
            • Oct 2011
            • 19
            Thank u all for u r good suggestions. I think now i have a choice for ir5180.
            • teckat
              • 16083
              u better make sure the fuser unit has been replaced recently / ask for paperwork on it-
              these units can cost between 800.00/1,200 US dollars to replace- there is no rebuilding these in the field anymore
              • Mrigen
                • Oct 2011
                • 19
                Is there any way to know how many paperwork done the fuser unit ?????
                • teckat
                  • 16083
                  First --Get yourself a 5180 service manual
                  Next---u need to check if 5180 has latest firmware -
                  Run some PG 10's test prints- to inspect for Fix unit surface wear or damage-
                  check error log for E007 codes> if not cleared already
                  FUSER.JPGpicture of new unit/
                  could check counter in service mode
                  SERVICE MODE
                  press *Additional Functions Key (once)
                  press #2 & 8 key at the same time (release both)
                  then press *Additional Functions Key again (release it)
                  the service mode is for experience tech's/
                  u can cause issues & problems if not familiar with it
                  COPIER > COUNTER > DRBL-1 > FIX-BLT-U
                  COPIER > COUNTER > DRBL-1 > FIX-BLT-L
                  you should not clear these counters unless u replace entire unit/
                  a third party or fourth party may have done so for sales purpose
                  if u ever need to replace a Fix unit > u need to run this adjustment
                  Enter the Service mode--only run this when replacing a unit
                  COPIER > FUNCTION > FIXING > FX-UHP-S > OK
                  --Check that 'FX-UHP-S is OK (It will take for about 3 minutes.)
                  Then Select COPIER > FUNCTION > FIXING > FX-LHP-S > OK
                  --Check that 'FX- LHP -S is OK (It will take for about 5 minutes.)
