Re: hai dhanesh i am joju with you i am from kerala i am working in dubai
U sure it is E031 ????
even though this code points to option counter, it can be caused by a short / check wiring to DC Controller-
& check for your 24v on front door switch
were u working on printer before code ?????
E031----(The option counter has an open circuit.)
When the accessories counter is off, an open circuit is detected in the
accessory counter--
check connector/wiring/ or replace counter
or DC PCB could be bad
also check below for broken wires or short to frame
Electromagnetic clutch (CL15) for vertical path drive (harness broken)- Short ???
accessory counter--
