canon ir1600
  • nawandyo
    • Aug 2025
    canon ir1600
    please help i have this canon ir1600 i have been servicing for paper jam. however now the problem is that it now picks two papers and displayes msg incorrect paper size if i use try 1 however if i use bypass its ok.
    help
    thank you in advance
  • teckat
    • 16083
    Re: canon ir1600
    help
    Easy fix> clean or replace tray rollers/ also inspect the shaft (bent)??
    inspect or replace Cassette Pickup Solenoid SL151.
    The solenoid should only be triggered when PS152 the retry sensor does not detect the leading edge of the paper within a specific period of time.
    try fresh ream of paper
    • ernesto
      • Oct 2011
      • 430
      Re: canon ir1600
      help
      Hi IR 1600 picks two papers first one and after the other paper, because the solenoid don t return at time and the pick ups turn around twice. it is the sound absorber of the solenoid is sticky.
