Running on Mac osX 10.6.8 Every time I send a job, it pauses and doesn't leave the Job cue from my computer...and doesnt go anywhere. But if I Open the toner door it does shoe on the print cue it's open... ANY SUGGESTIONS
IR C3220 - HELP NEEDED
Re: IR C3220 - HELP NEEDED
do u have a Fiery(imagePass) connected ?
what/ if any messages on control panel ( add toner/empty waste/replace drum ------etc.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
i_FJ
Yes it does have a fiery... THe funny part is that Im the only one on a MAC in the Office!!! Everyone else can print to that machine from their PC's.Comment
is it a Fiery C2 ?
re-load the print driver**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
i_FJ
The problem is that at this point I dont know which one to use?
So many drivers and I've been reading not to use some...
It's getting really frustratingComment
Where did you get the print driver from that you are currently using? There is a fiery express driver that came out with the LION OS over the summer time that is supposed to work with the C2. You can download that from driver here>>>Canon U.S.A. : Support & Drivers : imagePASS-C2
Just choose your OS and download and install the file.
I would completely delete everything you have now.Accidents don't just happen. They must be carelessly planned.Comment
i_FJ
There is deleter for Mac from this link:
EFI - Support - Software & Drivers Download
Look for Fiery Software Uninstaller for Mac OSX, while at it you might want to check if you printing woes was due to Fiery Print Driver Update for Mac OS 10.6 not installed in your Mac OS 10.6 Snow Leopard.Comment
