top edge black some time in canon ir3235N
  • dilip_22
    • Sep 2011
    • 20
    [Misc] top edge black some time in canon ir3235N
    Hi Friends,
    I have supplied a brand new canon copier ir3235N, after installation first copy came top edge black nearly 2 inch. Then after few copies copy is ok but after 2 or 3 days again same problem. then after few copies it is ok. but I think it will be happen again. Machine is new and meter reading not even 500.
    Please can you advise what is the exact problem. please reply some one soon.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5011
    Re: top edge black some time in canon ir3235N
    Need to investigate dude! Do you have the same issue with print because canon have bulletin
    for replacing Carriage Unit and CCD Cable
    • charm5496
      • 2387
      Originally posted by dilip_22
      Hi Friends,
      this is normal on a new setup with this model. We see it every week and it is nothing to worry about.
      • zoraldinho
        • Mar 2008
        • 5011
        Top edge black? Reely?
        • dilip_22
          • Sep 2011
          • 20
          Thanks friend, when i print user data list is ok, but for copying only problem
          After few copies it will copy very clear.
          • zoraldinho
            • Mar 2008
            • 5011
            No damage if you reed this pdf...
            ir4570-103.pdf
            • charm5496
              • 2387
              its not solid, but dirty streaks from doing the toner stir on the empty developer. It gets on the drum and transfer roller and after a few pages cleans itself off.
              • zoraldinho
                • Mar 2008
                • 5011
                Thanks for the info.I never see this kind of problem.
                • dilip_22
                  • Sep 2011
                  • 20
                  thanks friend, I checked developer , toner is enough in the developer.
                  magnet roller also ok.
                  • dilip_22
                    • Sep 2011
                    • 20
                    hi friends , pls see the attachment & advise me. This type of copy is coming every after 2-3 days.
                    • dilip_22
                      • Sep 2011
                      • 20
                      hi charm, can you please give idea what action should be apply in this problem. thanks
