Canon Fax L-280 Reset code for scanner
  • cheapread
    • Nov 2008
    • 12
    Hi, when you scan/copy a page into the machine, it comes out with about 1" of black lines all down the RightHandSide of the copied page - I believe there is a reset code you can key in
    reset the led bank - would appreciate any help - many thanks - Don
  • Hopper
    • Jul 2008
    • 173
    Re: Canon Fax L-280 Reset code for scanner
    Have you tried cleaning the slit glass that the page scans across?
    • cheapread
      • Nov 2008
      • 12
      Yes I have done that - I am looking for a s/w reset code that you key into the front panel... akin to HP's Cold Reset..etc
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Make a print .Maybe is cartridge issue.You can't reset scanner with code,but you can calibrate it.
        • cheapread
          • Nov 2008
          • 12
          Thanks for reply Zora, how do you calibrate it?
          Don
          • zoraldinho
            • Mar 2008
            • 5007
            Calibration can't help with stripes!
            The image has vertical stripes.
            (1) Clean the contact sensor's scanning glass.
            (2) Check the connection between the contact sensor and SCNT board (J2).
            (3) Replace the contact sensor unit.
            The image has thick vertical stripes.
            • cheapread
              • Nov 2008
              • 12
              thanks Zora -
              DON
              • zoraldinho
                • Mar 2008
                • 5007
