Canon Laser Class 710 faxing out problem
  • landspeeder
    • Feb 2010
    • 355
    So this machine receives but it will not send 99% of the time.
    Keep getting the NG fax printout.
    Once in a while it will send on a redial......thats the 1% of the time. Customer said last week when this all started the send lite stayed on for about a hour until they unplugged the fax and then replugged it. At this point only incoming was available but not sending. So is this a NCU board problem or deeper. Its a contract fax so I have to be carefull on whats spent. Have a great one!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • Hopper
    • Jul 2008
    • 173
    Re: Canon Laser Class 710 faxing out problem
    Put a piece of paper in the doc feeder and see how much memory is available/used.
    Call the fax number with your cell phone and listen for noise.
    Try a different trusted fax number.
    • landspeeder
      • Feb 2010
      • 355
      so on site the line is noisy....but they dont believe me...how rude......so I take in a loaner Panafax 890 and I would have bet it would work but it did ...so back to the shop with the canon and it doesnt fax out on our line....it dials, connects and sits for a coffee or two then gives the NG page...but it receives just fine...hmmm
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Plug the fax line in to analog regular phone and try to call out.This is ussualy line issue.
        • teckat
          • 16083
          any ERROR Codes
          Telephone Line Voltages: Fax machines communicate over single line phone networks where the 'Ring' and 'Tip' voltages are always located across the two center terminals.
          Line voltages are checked accordingly:
          on-hook voltage (phone is hung up)
          --set the volt meter to 200 vdc
          --should read within the 48vdc ~ 52vdc range
          off-hook voltage (phone is off-hook and dial tone is generated)
          --should read within the 8 vdc ~ 12 vdc range
          ringing voltage (incoming call)
          --set the volt meter to 200 vac
          --should read within the 75 vac ~ 105 vac range
          -RJ11-C Modular jack: Testing phone line voltages can be difficult if not impossible at times unless you can establish a really good connection to the phone line. The RJ11-C box can be used to establish a good connection.
          --RJ11-C box with two female connectors (remove the cover and test with your meter across the red and green terminals). An additional phone cable is required.
          --RJ11-C box with one male and one female connector; remove the cover and test with your meter across the red and green terminals).
          • landspeeder
            • Feb 2010
            • 355
            One of the service guys here found on a site how to clear all memory back to factory settings...so we tryed it and it worked....I should have thought of this first before I carted the fax into the shop...I feel like a failure.....I must take a pay cut.....
            Im over it ya just gotta learn something new everyday!!! wheres my money.....
            • teckat
              • 16083
              http://www.mediamuffin.com/11
