irc 5185 display
  • Apach
    • 157
    irc 5185 display
    Today after powering ON , display dont work on touch. Im try to enter in service mode and this is OK but latter I cant exit because key dont work, then I try enter in level 2 and is OK but exit not. Someone have idea what is problem or I have gremlins
    There is no stupid question, just stupid answer
  • teckat
    • 16083
    Re: irc 5185 display
    check for a stuck key/ test all for response /
    remove memory/clean ends/ re-seat it
    • Apach
      • 157
      >This device make me a crazy. After 900k copies whithout any problems (with regular service and replacment parts) I replace toghether Fixing asm., ITB, all drums, all rollers, cleaning blade. Now I have idea to replace and display and I have new device
      Is there a Z-fold module that can be mounted on this device?
      • charm5496
        • 2387
        No Z fold option was made for this model
        • Apach
          • 157
          I know that is not made ​​specifically for this model but Canon uses much the same things on different devices. It is possible that one model can be installed on the other, though not specifically designed for this model.
          example:
          FG6-8989 TRANSFER CLEANING ASSEMBLY
          Its the same for 5185 and 3200
          Belt the same (only belt not set)
          Toner
          etc. ....
          It is easy possible that some Z-fodl module can be connected to 5185
          • vigour
            • Aug 2010
            • 1038
            did you turn it off a lot when you had fuser problems?
            i just had to format and reload a 5570 with the same symptoms.
            reloading only does not work. never seen this before.
            i was about to change the lcd, and luckily i spoke to the regular tech, who clued me in to the fact that on all their machines he has had to format and reload after they have an ecode , because they turnoff and on until the drive gets corrupted.
            • vigour
              • Aug 2010
              • 1038
              first it has to physically fit, entrance height has to be exactly in the right spot. and the same with exit height going to the finisher.
              next the signals have to be programmed.
              • teckat
                • 16083
                Originally posted by vigour
                first it has to physically fit, entrance height has to be exactly in the right spot. and the seme with exit height going to the finisher.
                8" Folding Bone - For Manual Folding
                cfsbindingsupplies_2184_3845544.jpgThe most basic folding accessory available, folding bones (bone folders) are used for manually creasing/folding paper by hand.
                <font face="arial, helvetica" size="2">
