know solving a error code
  • dr.mansoor
    • Nov 2011
    • 12
    Re: know solving a error code
    hi dear friend.plz send me chapter 2 and 3 of service manual.thanks and the paper jummed in dupplex of meshine.what is the problem? plz guide me for solving it.
    • vigour
      • Aug 2010
      • 1038
      whats is the jam code.
      how many copies on m/c
      could be your duplex rollers or clutch
      could be your inner delivery rollers.
      could be a nick in the sensor actuator.
      • dr.mansoor
        • Nov 2011
        • 12
        canon ir 105 software
        *hi. plz send me software of canon ir 105+ *. thanks
        • dr.mansoor
          • Nov 2011
          • 12
          #19
          hi.my system show error codes 0993 and 0995 and 0996 and 0997 seperately.what is the problem?u know my system is ir 105+.thanks
          • charm5496
            • 2387
            #20
            are those errors or jam codes?
            • dr.mansoor
              • Nov 2011
              • 12
              #21
              hiii. jam code.what means this codes?thanks
              • charm5496
                • 2387
                #22
                well one would be an error code....for example when you get an error the screen changes and gives you an error like E732-0001 switch power off and on.
                the other is a jam code where the paper jams in the machine. the screen shows you instructions on how to remove the jam and then your machine goes through a rotation cycle and warms back up to start the job again without power cycling.
                when you got those codes did you get them from service mode? if so what area in service mode did you get them from?
                  • 16083
                  #23
                  are u a copier tech or a car mechanic working on a copier
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 5007
                    #24
                    It's adoctor.
                    • zoraldinho
                      • Mar 2008
                      • 5007
                      #25
                      It's a doctor.
                      • dr.mansoor
                        • Nov 2011
                        • 12
                        #26
                        well one would be an error code....for example when you get an error the screen changes and gives you an error like E732-0001 switch power off and on. the other is a jam code where the paper jams in the machine. the screen shows you instructions on how to remove the jam and then your machine goes through a rotation cycle and warms back up to start the job again without power cycling. when you got those codes did you get them from service mode? if so what area in service mode did you get them from?
                        no.the screen changed ang give me thats error and switch power off and on.then i power off the system and copy was go on.but i dont know means of that errors.in service manual wasent thats error.
                        • zoraldinho
                          • Mar 2008
                          • 5007
                          #27
                          • dr.mansoor
                            • Nov 2011
                            • 12
                            #28
                            Originally posted by zoraldinho
                            [ATTACH=CONFIG]14428[/ATTACH]
                            thanks.but my errors is 0993
                            • dr.mansoor
                              • Nov 2011
                              • 12
                              #29
                              Originally posted by teckat
                              are u a copier tech or a car mechanic working on a copier [ATTACH=CONFIG]14356[/ATTACH]
                              im a dr. but i have a canon ir 105+.
                              • Oze
                                Ricoh Fanboy
                                • 1663
                                #30
                                So NOT a copier technician?
                                The iR105+ is a complicated machine even for a tech with experience...best leave troubleshooting to the techs...after all I bet if I iasked you how to take out my own gallbladder you'll recomend me finding a doctor
