CLC 1180 RIP problem
  • GromBG
    • Oct 2010
    • 24
    Guys i have problem with my RIP at Canon CLC1180, problem is that he is dead so can u give me some proposal for solution of this problem, can i install new system (and how and where to get system) if is HDD problem or can i buy other rip,and offcourse does any other rip can be instaled on same machine from other brands?
    Tnx
  • charm5496
    • 2387
    Re: CLC 1180 RIP problem
    First off what model Colorpass do you have?
    You say it is dead. Do you have power inside the unit going to all of your motherboard and peripherals? It could be a power supply issue
    If it just not booting and loading then yes you could have a bad HDD or it might need reloading.
    • DANIELCANON
      • Jun 2011
      • 187
      Cual es el modelo de su servidor y a que se refiere con muerto. No enciende nada? O enciende pero no carga o sale algun mensaje?
        • 16083
        Tnx
        what rip do u have ?
        Z500e
        Z400e
        Z400
        • kraudy
          • Aug 2011
          • 5
          Tnx
          Hello,
          I am work with clc 1180 and colorpass for many year, i can help if you explain better the problem.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Some of the mentioned controllers have bulletins about new power Supply Unit.
            Probably have a new rip already.
            • KL568
              _
              • Feb 2011
              • 324
              Affected RIP are Z40e and Z400e, whereby their power supply switch have poor soldering joints problem. This causes the power to be intermittent OFF and then ON. As these RIPs OS are NT-embedded, this cause havoc to it. Could try and strip out the power supply and get the ON/OFF switch replace and give it a proper soldering.
              Z500e is affected as it power supply is different and chance of it WinXP-embedded corrupted is low.
