RDF-D1 Trivia?
  • costd
    • Jan 2008
    • 409
    RDF-D1 Trivia?
    What is the purpose/function of the Jump Lever (part numberFC2-2907-000, fig P16, item 83)?
    Do not know the answer, but several of us noticed it does not have any obvious function.
  • yourownfree
    • Dec 2007
    • 474
    Obviously its only on the newer version. i have a book and it doesn't even go there. looked up on Canon site and there is one. i looked on a machine here, there isn't one. the stepped screw, one each side prevents rdf assy from opening any further when it reaches its limit, so it wont go beyond. Whatever the lever is, or does, is beyond me. I don't have one to look at. So humor us.
    Maybe it was put there to do just that, humor us.
    • wagon
      Village Idiot
      • Dec 2006
      • 654
      I am not a Canon tech, but, why not disconnect the sensor and see what it does wrong?
      If you are hitting your head up against a wall it always feels better when you stop.
      • Canuck
        Tech Specialist
        • 1713
        I looked at the diagram...it also has a torsion spring on it...looks pretty useless..maybe keeps tension on document tray mount brackets so that drive belt doesn't jump when tray leaves position..diagram only shows one at rear...no idea
          • 23010
          You've got my curiosity. Can you post a photo? Or maybe just the parts diagram exploded view? I don't have any RDF-D1s around to look at, but I did work on them for 6 years.
          • costd
            • Jan 2008
            • 409
            No sensor - it just has the spring and attaches to the side of the document tray. It piviots as the tray goes down - but does not touch anything else (other than the bottom - and that does not have a stop/sensor). BTW: spring is too light to be a "return" assist.
            I did take pictures and will post them after I get home as I do not have my data cable here.
            First shot at adding the photo.
            • Canuck
              Tech Specialist
              • 1713
              Now i'm really curious...i gotta see one of these..
                • 23010
                Left feed stopper arm solenoid, maybe....
                I'm thinking that this is the stopper arm solenoid. If I'm correct, if you unplug this solenoid the left side stoppers will not lower, and you'll get jams left feed, but not right feed.
                • costd
                  • Jan 2008
                  • 409
                  As shown in the picture - it is not a solenoid. Just a white plastic arm with a light spring attached to the side of the tray arm. I suspect it is suppose to "assist" the arm in "rebounding" the platform - just seems like a really light spring for that.
                  Oh well, I really appreciate all the efforts but this may have to go in the same box as where Jimmy is buried.
