DADF-N1 SWAP with DADF-h1? Possible?
  • mrfuser
    • 1626
    Does anyone know if you can swap the feeder from a iR3570 to an iR3300?
    Kelly
  • charm5496
    • 2387
    Re: DADF-N1 SWAP with DADF-h1? Possible?
    controllers would have to be changed and the individual parts swap from one to the other so it might just operate fine if you try it.
    • mrfuser
      • 1626
      So just swap boards?
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        Canon have the same parts with different catalog numbers.Canon says NO you can't,but if you have time,swap the parts and report.
        Good luck
        • charm5496
          • 2387
          you will have to take a look to make sure that all of your connectors match up between the two. If that is the case then go for it. I do not have either in front of me so I cannot verify at the moment.
