ir4570 server not located
  • kevin
    • Nov 2011
    • 10
    pinged server, all ok,trying to send to file on one touch. computer servers name server. domain WORKGROUP,when i program one touch host name //server. file L:FAXES then user_name I get unable to locate server or server not found something like that what am i doing wrong. universal print kit is licensed. I believe its something I'm missing in programming one touch.Customer is happy because machine wasn't working at all before i replaced main controller,was intermittently powering on @ off by itself. can't print out user print because old board wouldn't give me time too. everything works now except scannig to file. Any suggestions ,ty kevin
  • KL568
    _
    • Feb 2011
    • 324
    Re: ir4570 server not located
    Think your file path specify might be wrong. it should be :
    \\server\SharedFolder
    Settings for "File" can leave blank unless you need to send it the sub-folder of "SharedFolder"
    • ernesto
      • Oct 2011
      • 430
      Settings for "File" can leave blank unless you it sub-folder of "SharedFolder"
      Hi, sorry I don t understand about what you tell, but if you want to scan you have to install scangear program...
      I am sorry again.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        I am sorry again.
        You don't need scan gear if you have send kit installed.
        Kevin.What's hapend when you browse for files on network?
        - Reset server.
        - Check server status and settings.
        • Herrmann
          • Jan 2006
          • 792
          maybe your dns setting is wrong/not exist, so this does not work with names. Type the ip Adress instead, what happens?
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • jiongpao
            • May 2009
            • 414
            Hi, im sorry to post here about the manual since this thread is running may i ask for the part manual of ir4570? Its really hard to order somethings from supplier since everytime they are asking for part number for certain parts. But curious thing is we having difficulty for requesting the part manual from them, i dont even know why since we bought that machines and parts from them. Thanks
            • kevin
              • Nov 2011
              • 10
              what happens when u browse
              it asks for password
              • zoraldinho
                • Mar 2008
                • 5015
                Re: what happens when u browse
                Check DNS or proxy maybe.
                Try to set on dhcp,restart the printer,turn off dhcp and manually turn back existing IP adress.
                If you have properly installed network settings,you don't need password for browsing for files.
                • Herrmann
                  • Jan 2006
                  • 792
                  i am not sure, if you are right, zoraldinho, maybe he need to enter username and password of the server, to go further with browsing.
                  • zoraldinho
                    • Mar 2008
                    • 5015
                    My bad with words.Thanks Hermann.For browsing servers and not files.If you won't see files,need password.
