My costumer has IR 5075 and he is calling and telling me that the IR got error 0423-002. i just take a look to the Service manual and saw that the SDRAM has a problem. perhaps some one can give me some explanations. thanks....
E 0423-002
Re: E 0423-002
- When a faulty image ascribed to CIS scanning side occurs at both-side simultaneous scanning, re-fit J308 connector on the Interface PCB, and then make copies.
- Suspect poor connection of the DIMM mounted on the backside of the Memory PCB found in the Reader unit, remove the DIMM, clean its terminal with lint-free paper moistened with alcohol, re-fit the DIMM, and then make copies again.
- Re-fit all the connectors on the Memory PCB.
- If the symptom still occurs, replace the DIMM with a new one.
- WA7-4603-000 : iR5075 Series (Now deleted, see note below)
- WA7-4751-000 : iR C5185 (Now deleted, see note below)
- If the symptom still occurs, suspect a fault in the Memory PCB, and replace it with a new one.
- FM3-0472-000 / New PN: FM3-4436-000 : iR5075 Series
NOTE: In order to improve reliability, the DIMM installed to the socket of the Memory PCB is now surface mounted. Accordingly, delete the DIMM (WA7-4603-000) which is now included with FM3-4436-000.
Re: E 0423-002
Hope this helps.
Problems occur in so-dimm. I replaced it with a new one, hola successfully.
thank you ..Comment
