E 0423-002
  • adhy
    • Feb 2011
    • 109
    [Error Code] E 0423-002
    My costumer has IR 5075 and he is calling and telling me that the IR got error 0423-002. i just take a look to the Service manual and saw that the SDRAM has a problem. perhaps some one can give me some explanations. thanks....
  • zooee
    • Jun 2013
    • 5
    Re: E 0423-002
    I also experienced the same problem, anyone have a solution?
    Please help!!
    • canonbundy
      • Jun 2012
      • 607
      Re: E 0423-002
      Hope this helps.
      1. When a faulty image ascribed to CIS scanning side occurs at both-side simultaneous scanning, re-fit J308 connector on the Interface PCB, and then make copies.
      2. Suspect poor connection of the DIMM mounted on the backside of the Memory PCB found in the Reader unit, remove the DIMM, clean its terminal with lint-free paper moistened with alcohol, re-fit the DIMM, and then make copies again.
      3. Re-fit all the connectors on the Memory PCB.
      1. If the symptom still occurs, replace the DIMM with a new one.
      2. WA7-4603-000 : iR5075 Series (Now deleted, see note below)
      • WA7-4751-000 : iR C5185 (Now deleted, see note below)
      1. If the symptom still occurs, suspect a fault in the Memory PCB, and replace it with a new one.
        • FM3-0472-000 / New PN: FM3-4436-000 : iR5075 Series
          NOTE: In order to improve reliability, the DIMM installed to the socket of the Memory PCB is now surface mounted. Accordingly, delete the DIMM (WA7-4603-000) which is now included with FM3-4436-000.
      • zooee
        • Jun 2013
        • 5
        Re: E 0423-002
        Originally posted by canonbundy
        Hope this helps.
        I tried your suggestion, it worked!
        Problems occur in so-dimm. I replaced it with a new one, hola successfully.
        thank you ..
        • canonbundy
          • Jun 2012
          • 607
          Re: E 0423-002
          thank you ..
          Great stuff - happy to help .
