PC745 Shows Paper jam after about 4 seconds after press print button
  • 639mpa
    • Aug 2025
    [Jamming] PC745 Shows Paper jam after about 4 seconds after press print button
    Ive checked entire copier for paper debris etc but there is nothing in the system. If I turn off power ther repower the paper jam light comes on 4 sec after i press the print button. Checked connections. Is it the bypass tray sensor? Where can i get a parts list and locate parts
    Any help greatly apprecited
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: PC745 Shows Paper jam after about 4 seconds after press print button
    Paper jam but no paper?
    jamed paper?
    Paper pick up rollers spin?
    Are you a tech?
    • livancicm
      • Sep 2008
      • 96
      clean or change exp lamp
      • 639mpa
        Paper is in the tray. No paper is jammed anywhere in the machine. When the print button is pressed the rollers do not spin and after about 4 seconds the jam light next to the print button comes on and the printer stops.
        I mainly service and repair new and used toy trains including electronics . I once repaired tv's and radios. I have repaired several copiers. this copier is for my shop and I need it for the holidays.
        Thanks for help
