Canon np6521, error E-220
  • serge dugal
    • Jan 2008
    • 27
    Hi.
    I change the exposure lamp with a used one, adjust the heater properly,still give me the same error.
    • 22930
    An E220 error means that the machine did not detect the correct amount of light. There can be several reasons for this:
    1) Sure, the most common is the lamp flickering, lighting slowly, or not reaching the optimum brightness. A bad lamp can do this.
    2) Next most common is a lamp heater that has slipped out of position & is blocking the intensity sensor. (bottom center) it sounds like you thought of that one too.
    3) How about the white level reference (dirty, peeling, discolored).
    4) Lamp inverter
    5) How about enviromental temperature? I didn't notice what area you're from, but temperatures below 10C cause the lamp to light slowly.
    6) Failed lamp heater
    • serge dugal
      • Jan 2008
      • 27
      thanks
      Thank you for the informations.
      Serge
