Transfer problem on IR Adv 7065
  • Van Steal
    • 177
    [CQ] Transfer problem on IR Adv 7065
    Hi all,
    Have a problem with the image being transfered to card from the belt after replacing the 2nd transfer roller and and the 2nd transfer holder ass'y inner. It worked fine for a day or two then came back with this problem. I'm going back to check that units were fitted correctly but was wondering if anyone had this fault. it works fine on paper
  • Herrmann
    • Jan 2006
    • 792
    Re: Transfer problem on IR Adv 7065
    Did you reset the counter settings after replacement? this is very important on these mashines.
    please post a scan of the print, so we can see more
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
