IR2270 paper jam
  • LennoxD
    • Sep 2011
    • 82
    IR2270 paper jam
    Paper jam indication as copier is turned on first thing in the morning. Check and there is no paper anywhere.
  • logonjim
    • 136
    Re: IR2270 paper jam
    Jam codes pls
    • squidmo
      • Aug 2011
      • 3
      I had the same issue on IR4570. my problem was that the registration sensor flag was getting stuck on the foam piece towards the back of the machine. you should check that. and replace that foam piece.
      • LennoxD
        • Sep 2011
        • 82
        Sorry no jam code was indicated when I check the jam log
        • teckat
          • 16083
          u don't have one jam code listed in the log
          do u see a FF03 jam indication message on panel
          • nazmi_exa
            • Nov 2009
            • 24
            your situation when the machine detect paper jam although there is no paper inside mean your have a problem with feeding unit..its always happen to canon IR model such as IR3300, IR4570 and etc..u should take out the whole feeding unit and check its sensor (maybe broken flag sensor) or any broken/loose gear...when the feeding cannot pick up the paper, paper jam sign will appear in screen..for troubleshooting use your bypass and see same problem happen or not..
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5015
              This is it!
