IR 2270 scan to folder
+ More Options
Posts
  • Hopper
    • Jul 2008
    • 173
    So I set up a shared scan folder on a PC. Got it's host name and password. Go to the Canon and put in the Host name, Path, user and password. It would not go through under FTP. It does go through sending it as Windows SMB.
    But, when I go to the folder and open it as a pdf it is all gobble dee gook.
    nevermind....
    I just fixed the problem as I typed this. The goble dee gook looked like /html/meta/hieght... I realized I was opening up with browser. I did a right click open with Adobe and it is perfect.
    May this post will help someone.
    Hopper
  • teckat
    • 16083
    Re: IR 2270 scan to folder
    • Herrmann
      • Jan 2006
      • 792
      FTP is not name based, it is ip based. Remove the name and enter the ip of destination and you are done
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
