E000 code
  • julio ortiz
    E000 code
    I had an E000 code on a canon 210S, I checked the fuser unit and found it to be in bad shape,so I order a fuser unit and replaced it. My problem is that I don't know how to reset the fuser error code. I've try the star 28 star to get into the program but that's not working,I know that is not it because it does'nt come up. Can any one steer me in the right direction?
    • 23009
    Forgive me if I miss a few key strokes:
    *28* (use the * inside the head shape, not the * on the keypad)
    Function, Error, Clear.
    It took me a few tries to figure that out myself.
    (That's my old home town, Chicago)
    • imaginGuru
      an
      Are you a tech?.
      Perhaps one of your button-switches in the panel control is not working,
      it is more trouble, but If you're already stucked at this point I would try anything.
      Disassemble the panel control so you can reach the solder points of the following keys *,2,8
      and check them (with DMM) for positive continuity when pressed, otherwise change the ones not working, reassemble and try again.
      imaginGuru
      • 11x17
        • Apr 2007
        • 153
        Are we sure that this isn't a model where you oppen the front door and activate the service switch with a paper clip?
        • julio ortiz
          E000 code
          I've tried *28*,that did'nt work,also tried the paper clip in the hole on the front of copier when you open door,that did'nt work
          • 11x17
            • Apr 2007
            • 153
            If there is a hole in the front cover then you should seea dollar sign onthe control panel once you push it. After that you need to push aditional functions then 4 to get into service mode to execute eror clear
            • khattab.al.masry
              • 212
              Re: E000 code
              the service mode range may be changed so check the follow the case with setting range "1"
              service mode
              copier
              level 2
              option
              body
              SVMD-ENT-----
              Switch the method of entering the service mode.
              Setting range
              0: Press the [User Mode] key. --> Press [2] and [8] at the same time. --> Press the [User Mode]
              key.
              1: Press the [User Mode: key. --> Press [4] and [9] at the same time. --> Press the [User Mode]
              key.
              Standard value 0
