Ir7095 cassettes
  • jiongpao
    • May 2009
    • 413
    Ir7095 cassettes
    Hi, today we service another ir7095 machine. The problem is cassettes 2,3 and 4 unable to pull the paper up and it show jam. It can detect the paper but it seems pick-up, feed and separation roller doesn't function at all. Cassette 1 running fine. Base on the jam code 102, 103 and 104 I did cleaned all the pick-up sensors but no cure. Is there anything that I miss out or any clues? Thanks
  • vigour
    • Aug 2010
    • 1038
    Re: Ir7095 cassettes
    how many copies on each cassette?
    seems you need to replaCE those rollers.
    • jiongpao
      • May 2009
      • 413
      We changed all rollers including pick-up, feed and separation rollers for all cassettes 1,2,3 and 4 since we serviced it all at once.
      Originally posted by spectraindo
      Check the Timing Belt at the Rear of the machine maybe its broken.
      i will go through the SM about the actual timing belt location and will feed back
