canon ir 2022
  • Saji
    • May 2010
    • 97
    [Misc] canon ir 2022
    Canon ir 2022 showing Set correct paper size, after one or two copies,( Paper selector is ok.) once off and on machine make one or two copy again, then it start shows set correct paper size again.both cassettes gives the same problom..please help me to solve it,
    thanks in advance.
  • Gerhard
    • Oct 2009
    • 99
    Re: canon ir 2022
    Hi
    You must check the vertical path and registraion areas. Youve probably got a sensor thats getting stuck and reading the wrong paper length. Hope this helps!!
    Regards
    sigpic
    Life is a Journey enjoy the ride !!!
    • mramlawi
      • Jul 2011
      • 838
      Re: canon ir 2022
      hello
      it happend so many times with me in Canon IR 2018 \
      its the unit feed problem you must disassemble it and check if the solonid works fine put some lubricates,if didnt work replace the unit
      waitin ur reply
      Distinguished road makes you jewel in rough
      • teckat
        • 16083
        Re: canon ir 2022
        thanks in advance.
        add an extra wrap to the spring for the Registration Sensor (SR209) flag should resolve the issue
        CASSETTE FEEDER ASSEMBLY
        or check/replace >> Size Detection Assy.
        • Saji
          • May 2010
          • 97
          Re: canon ir 2022
          An extra wrap to to Registration sensor activator spring solved the problom, as suggested as Sir teckat.thanks to all, specially to sir Teckat.
          • teckat
            • 16083
            Re: canon ir 2022
            THANKS,
            • Rakesh
              • May 2012
              • 72
              Re: canon ir 2022
              thanks..
              View Life As A Continuous Learning Experience...
              • mramlawi
                • Jul 2011
                • 838
                Re: canon ir 2022
                Originally posted by teckat
                [ATTACH=CONFIG]13297[/ATTACH]
                THANKS,
                thanks also it works with me
